Fiyatıyla herkese hitap etmese de, şöyle bir montaj videosu var Banshee nin...
Technical features
** 3-speed belt drive
** Automatic tail rotor drive belt tensioner/-spring damper
** Main drive belt tensioner
** 30 mm carbon-fiber, strutless, tail boom
** Straight swashplate linkage
** Extremely small, compact design with high torsional stiffness
** Center of gravity close to the rotor plane
** Double (x2 separate units) needle bearing clutch
Technical specifications
** Basic weight of the mechanics including canopy: 1.65 Kg´s (not including: motor, servos, regulator, batteries or rotor blades)
** All up weight with standard equipment ~2950 g´s (3xBLS452, 1xBLS251, Jive 120+ HV, Pyro 700-52, BeastX, Maniac3 710 mm, 115 mm tail rotor blades, canopy)
** Main rotor blades: 690-720 mm
** Tail rotor blades: 105-120 mm
** Motor: 65 mm diameter max.
** Main rotor speed: 1000-2300 r.p.m.
** Variable reduction ratio between motor and intermediate shaft:
** 1:4 – 1:2.88 (18–25 drive belt pulley)
** Reduction ration between intermediate and main rotor shaft: 1:3
** Ratio between main rotor and tail rotor: 1:5.54
** Battery cell size: Maximum 60 mm width and 60 mm height
Fiyat vergi düşmüş hali 2025 euro ... Ortalama bekleme süresi 6 hafta
9dk ya kadar da uçabiliyor
Technical features
