Futaba 2 yeni modelle karşımızda. Aslında modeller çıkalı biraz zaman geçmiş ama biz fark etmedik galiba. İşte modellerimiz ve temel özellikleri
FUTABA T16SZ
Fiyat : $ 699
Link : https://www.futabarc.com/systems/futk9460-16sz/index.php
Ürün inceleme videosu
Genel özellikler
Compatible with FASSTest, FASST, T-FHSS and S-FHSS protocols
Full telemetry compatible
4.3" LCD touch screen
10 programmable mixes
S.Bus servo programming editor
S.Bus trainer port
3-axis gyro support
30-model memory with 15 character naming
3-axis gyro support
Swash and throttle mixing
V-tail mixing
Adjustable servo speed
AFR/DR
AFR curve mode (3)
AFR curve point (17 points)
Idle down
Logic switch
8 flight conditions
Throttle cut
Voice message/audio earphone jack
Micro memory card slot
Software updateable
Up/down/integral timer
Free online software upgrades
Lap timer memory
Stick calibration
180° antenna rotation and 90° angle adjustment
Multi language (9 languages)
EPA
FUTABA 12K
Fiyat : $ 450
Link : https://www.futabarc.com/systems/futk9280-12k/index.php
Channels: 14 (12 proportional, 2 switched)
Compatible with T-FHSS and S-FHSS protocols
Six 3-position switches, two 2-position switches, two slider levers, two rotary dials, four digital trims and two push buttons for quick, easy access
Headphone plug, trainer port and S.Bus plug-in
S.Bus2 system allows multiple servos, gyros and telemetry sensors with a minimum number of cables
Model types: six types of main wing with three tail types for airplanes, six swash types for helis and multi-rotor functions
Improved stick feel with adjustable lengths and tension
Dual rates/exponential
Included 6V 1800mAh NiMH battery and charger
Large, backlit LCD screen with adjustable contrast for easier reading. Push/dial operation simplifies set-up
Micro memory card slot for storing model information and free system updates. (SD-32MB to 2GB; SDHC-4GB to 32GB, not included)
Vibration feature alerts pilots to various alarms and timers, in addition to sound
10-character model naming
Expandable 30-model memory
5 flight conditions (Helicopter and Glider model selections)
5 customizable programmable mixes
Servo test and servo position display
Fuel mixing
Stick calibration
Servo speed
Logic switching
FUTABA T16SZ
Fiyat : $ 699
Genel özellikler
S.Bus trainer port
3-axis gyro support
3-axis gyro support
V-tail mixing
AFR/DR
AFR curve mode (3)
Idle down
Logic switch
8 flight conditions
Throttle cut
Software updateable
Lap timer memory
Stick calibration
EPA
FUTABA 12K
Fiyat : $ 450
Fuel mixing
Stick calibration
Servo speed
Logic switching
