Evet arkadaşlar,
Gün geçmiyor ki aramıza yeni bir SPEED tarzı model katılmasın. Eskinden sadece tek tük 1-2 firmada gördüğümüz SPEED modeli artık tüm markalar tarafından üretilmeye başlandı.
Bu kervane en son JR'da katılmış gözüküyor. Buyrun yeni piyasaya çıkacak model. Ama Palsiz Kit fiyatı beni benden almadı dersem yalan olur Bu fiyatla başarılar diliyorum
Ürün Linki : http://www.jramericas.com/234961/JRP988370/?pcat=1#
Fiyat : $1.300
Bazı teknik özellikler:
Features
Highly-accurate machined gears.
These gears can be also installed on Forza 700.
Shortened tail rotor blade to the limit of (92mm)
Newly-designed landing gear to reduce air resistance.
A front body covers the swash plate, mounted bottom cover to the lower frame.
Large front body ensures visibility even at high-speed.
Genuine Forza 700 rotor head for extreme 3D flight.
Pitch rod is upgraded to a turnbuckle threaded rod that is capable of fine-tuning.
Ample space for a larger motor and ESC. Pinion gear T13 (shaft dia. 6mm) is the standard feature. Motor KV 500-560 is recommended. (12S)
Specifications
Overall length : 1,399mm.
Overall height : 338mm.
Overall width : 165mm.
Main rotor diameter : 1,619mm.
Tail rotor diameter : 262mm.
Gross weight 4000g or more (not including battery).
Gear ratio : 8.62:1:4.72 (T112/T13).
Motor : 500 - 560KV Brushless motor.
ESC : 160A or more.
Battery : 12S4500mAh - 5000mAh.
Fiyat : $1.300
Features
Specifications
ESC : 160A or more.
